Home » Audio » General » Upgrading Computer
Upgrading Computer [message #78835] Wed, 01 January 2014 14:26 Go to next message
The Noise is currently offline  The Noise
I want to upgrade the way I listen to music on my laptop, but I don't want to make any sacrifices in performance anywhere else. Like the online courses that I take. Any suggestions?
Re: Upgrading Computer [message #78846 is a reply to message #78835] Thu, 02 January 2014 08:55 Go to previous messageGo to next message
What kind of sound card do you have on your computer? You can try upgrading the sound card and getting a pair of outboard speakers instead of relying on the computer speakers.
Re: Upgrading Computer [message #79035 is a reply to message #78835] Thu, 23 January 2014 01:44 Go to previous messageGo to next message
iLoveiPod is currently offline  iLoveiPod
Buy a nice set of computer speakers and it will make a big difference in how your music sounds coming through your computer. I would suggest something by Logitech; they make awesome speakers.
Re: Upgrading Computer [message #79040 is a reply to message #79035] Thu, 23 January 2014 16:33 Go to previous message
Hi, You can also get USB connected external "sound cards" I use one from SIIG that will do recording from analog sources, digital sources and feed either headphones or 7.1 (and 2,2.1,3 etc) analog and digital outputs. Small size (about 3X3X1 inches) and USB powered. They are currently about $75 new. Simple to use, no drivers or software needed for most of the features.
Previous Topic: Sensory Overload
Next Topic: All those dead electronics
Current Time: Wed Nov 04 08:02:16 CST 2026
