Home » Sponsored » Pi Speakers » 4pi: B&C DE 250 Impedance, is it 8 or 16 ohms? (Driver specs.)
icon12.gif  4pi: B&C DE 250 Impedance, is it 8 or 16 ohms? [message #78786] Fri, 27 December 2013 18:39 Go to next message
dmeckstr is currently offline  dmeckstr
Hi Wayne,
I noticed on the new version of the 4pi cross-over schematic that the tweeter is marked as 16 ohms. I wanted to confirm that with you (before I actually buy some Rolling Eyes).
Thanks again,
David
Re: 4pi: B&C DE 250 Impedance, is it 8 or 16 ohms? [message #78787 is a reply to message #78786] Fri, 27 December 2013 19:08 Go to previous messageGo to next message
No, the tweeter is 8Ω. The part you're referring to is Rs, which is a 16Ω, 10W resistor placed in shunt across the compression driver.
Re: 4pi: B&C DE 250 Impedance, is it 8 or 16 ohms? [message #78788 is a reply to message #78787] Fri, 27 December 2013 19:48 Go to previous messageGo to next message
Thanks Wayne,
I was just coming back on to say I looked at the schematic again and realized that there was a new part there. Also, I see a couple posts down you told someone you use the DE 250-8. :~
Re: 4pi: B&C DE 250 Impedance, is it 8 or 16 ohms? [message #78789 is a reply to message #78788] Sat, 28 December 2013 06:53 Go to previous messageGo to next message
Speaking of Ohms, I'm finally, with a lot of help from Professor Brown, building the 50 Watt Monoblocks. The 5K Hammond 1650R OPTs have 4, 8 and 16 Ohm taps. My 4 Pi 2226Js, are 16 Ohm and the DE-250s, as the OP discovered, are 8.
I'm going to have 8 and 16 Ohm outputs, which is best for the 4 Pis? I'd hate to lose 33% of the Wattage with too low an impedance.
Re: 4pi: B&C DE 250 Impedance, is it 8 or 16 ohms? [message #78790 is a reply to message #78789] Sat, 28 December 2013 08:58 Go to previous message
If the midwoofer is 16Ω, I'd probably choose the 16Ω tap.
Previous Topic: 4pi Speaker Plans, Please
Next Topic: Flanking subs and phase
Current Time: Thu Apr 25 16:16:04 CDT 2024
