Home » Sponsored » Pi Speakers » 4Pi... B&C DE250-8 or B&C DE250TN?
4Pi... B&C DE250-8 or B&C DE250TN? [message #78585] Sun, 08 December 2013 20:43 Go to next message
I was at Parts Express getting ready to order parts for my 4Pi build and I noticed that they now offer the B&C DE250TN 1" Titanium Compression Driver 8 Ohm.
Wayne, which is the best driver to go with for the 4Pi?
I am guessing you have the 4Pi voiced with the original B&C DE250-8, what would the TN version bring to the table?
Thx,
Tom
Re: 4Pi... B&C DE250-8 or B&C DE250TN? [message #78586 is a reply to message #78585] Mon, 09 December 2013 02:16 Go to previous messageGo to next message
All my speakers are designed to use the DE250-8. The titanium version may take more abuse, but it will have worse response due to breakup. The polyimide diaphragm provides better internal damping.
Re: 4Pi... B&C DE250-8 or B&C DE250TN? [message #78587 is a reply to message #78586] Mon, 09 December 2013 06:08 Go to previous messageGo to next message
Thanks Wayne!
That is what I thought would be the case.
Re: 4Pi... B&C DE250-8 or B&C DE250TN? [message #96234 is a reply to message #78587] Sat, 17 December 2022 15:54 Go to previous messageGo to next message
repeatafterme is currently offline  repeatafterme
I have the DE250TN with poly diaphragm. I believe that makes it a standard DE250-8. But I'd like to experiment with making my 4 Pi's sound "brighter". Could I put the titanium diaphragms back in and then adjust the crossover? I'm hoping there's a way to try it out without major surgery. Remove or jumper a resistor?
Maybe a better question to start with would be: would the titanium diaphragm make the horn sound "brighter"?
Any other ideas?
Thanks,
Re: 4Pi... B&C DE250-8 or B&C DE250TN? [message #96235 is a reply to message #96234] Sat, 17 December 2022 16:10 Go to previous message
Try installing a capacitor in position C1 and see how you like it. In the past, we used a 0.47uF value in that position to augment the top-octave.
Previous Topic: Speaker stands for Pi 3 or Pi 4
Next Topic: 4Pi Plans & a question
Current Time: Thu Oct 22 23:20:32 CDT 2026
