Home » Audio » Group Build » Build From Scratch Stereo Speakers
Build From Scratch Stereo Speakers [message #78017] Fri, 04 October 2013 15:36 Go to next message
Chase is currently offline  Chase
I am wanting to build my own speakers for the stereo in my bedroom. Looking to build the box and insides totally from scratch. Are there schematics for that on this site or something similar that I could get some ideas for?
Re: Build From Scratch Stereo Speakers [message #79258 is a reply to message #78017] Mon, 03 February 2014 17:24 Go to previous messageGo to next message
Headphones is currently offline  Headphones
I have never built stereo speakers from scratch, but if it were me, I would just look up a lot of information and techniques online first. Good luck.
Re: Build From Scratch Stereo Speakers [message #79285 is a reply to message #79258] Tue, 04 February 2014 20:24 Go to previous messageGo to next message
Hi, Try Parts Express forums and projects on the web. They do a lot of speaker building. Also Others on this forum may assist with plans. I think first you need to clue us in on size, cost and what you are going to drive them with.
Re: Build From Scratch Stereo Speakers [message #82052 is a reply to message #78017] Fri, 19 February 2016 06:29 Go to previous messageGo to next message
Lizah is currently offline  Lizah
It can definitely be done, but it will take some research to find out how to do it. You also have to decide what to enclose them in to make sure that the sound doesn't leak out.
Re: Build From Scratch Stereo Speakers [message #82055 is a reply to message #82052] Fri, 19 February 2016 10:34 Go to previous messageGo to next message
This whole forum is about building speakers and other gear. Scan through the archives; You'll find a ton of good stuff here.
Re: Build From Scratch Stereo Speakers [message #99268 is a reply to message #82052] Fri, 06 March 2026 15:22 Go to previous message
Hank is currently offline  Hank
Lizah wrote on Fri, 19 February 2016 06:29
There is a whole lot of information on this forum that can be of great help towards building such speakers. All it takes is relaxing and finding out which one works better and if one's budget can be able to cover it if they decide to go the diy route.
Previous Topic: Home-made Boomboxes
Next Topic: Kit vs. Finished Speakers
Current Time: Tue Sep 08 11:16:27 CDT 2026
