Home » Sponsored » Pi Speakers » what is "jumper" L1 in the Pi 3 crossover?
what is "jumper" L1 in the Pi 3 crossover? [message #77875] Tue, 17 September 2013 12:26 Go to next message
nikkoluvr is currently offline  nikkoluvr
probably been covered a thousand times, but I'm wondering what that component is? I'm assuming it's not just a piece of wire, which is what I thought a jumper would be, since it's labeled "L1"
thanks,
nikkoluvr
Re: what is "jumper" L1 in the Pi 3 crossover? [message #77876 is a reply to message #77875] Tue, 17 September 2013 17:46 Go to previous messageGo to next message
It's just a jumper wire. It's there because there is a place on the printed circuit board for an inductor. This wire completes the circuit, in absense of a physical coil.
Re: what is "jumper" L1 in the Pi 3 crossover? [message #77877 is a reply to message #77875] Tue, 17 September 2013 18:34 Go to previous message
thanks Wayne! much appreciated.
Jim
Previous Topic: First coil in woofer's LPF with and without helper woofers
Next Topic: More Live Nude Resistors
Current Time: Mon Oct 19 17:30:32 CDT 2026
