Home » Audio » Source » Cleaning Vinyl Records
Cleaning Vinyl Records [message #77372] Thu, 01 August 2013 09:49 Go to next message
Chicken is currently offline  Chicken
How do you clean your vinyl records? Do you wipe them with a soft cloth or do you use a cleaning solution? I've never seen anyone actually clean records other than blowing on them to get some dust off.
Re: Cleaning Vinyl Records [message #77377 is a reply to message #77372] Thu, 01 August 2013 14:30 Go to previous messageGo to next message
Hi, I use a Record Doctor machine now. Works great. For some time I used a Spin Clean. It worked OK, but the RD is is better.
Re: Cleaning Vinyl Records [message #77552 is a reply to message #77372] Wed, 21 August 2013 12:51 Go to previous message
Azuri is currently offline  Azuri
With the turntable I used to have, you could take off the part that houses the needle. With that off, just wrap a small cloth on the end of the tone arm and let it go trough the motions.
Previous Topic: What's the best Turntable new or used under 2K?
Next Topic: HDtracks
Current Time: Mon Nov 09 08:38:50 CST 2026
