Home » Audio » Craftsmen » piezo pick up issue.
piezo pick up issue. [message #77327] Tue, 30 July 2013 00:14 Go to next message
Soundsensor is currently offline  Soundsensor
I've made a piezo pick up for a homemade guitar that I am building.
It works quite well, except for the feedback.
It is a 76dB piezo buzzer from radio shack that it is made of. Can anyone tell me how I might be able to modify it so that the feedback is eliminated?
Re: piezo pick up issue. [message #77437 is a reply to message #77327] Wed, 07 August 2013 07:38 Go to previous message
Chicken is currently offline  Chicken
How did you attach it? I've read that foam or hot glue on the back of the pickup will help reduce feedback. Also, if you get close to the amp you'll run into feedback problems.
Previous Topic: Preamp for Low Output Moving Coil Cartridges
Next Topic: Laser Harp and Arduina
Current Time: Sat Oct 31 22:32:53 CDT 2026
