Home » Audio » Thermionic Emissions » 2A3 Upgrade (Paramour)
Re: tubes [message #10593 is a reply to message #10592] Thu, 08 April 2004 16:56 Go to previous messageGo to next message
Oh, yeah! I forgot about that!
Your Valve Art's are quieter? That, plus being blue, make's 'em quite a catch! I need to buy a few more so I can get a pair that aren't noisy.
As an aside, totally off-topic, I'm bustin' at the seams about a new project. You're gonna love it, as are all the other good woodsmiths. I can't wait to show and tell...
Re:Cool! I'm controversial! (nt) [message #10594 is a reply to message #10591] Thu, 08 April 2004 17:07 Go to previous messageGo to next message
Why of course, you're the controversial and elusive Till E. By the way, did you see the posts on the Craftsmen forum about a FAQ? I remembered at Lima, you suggested a video FAQ so I made mention of it. Seems like a pretty cool idea, to publish a how-to audio guide online, in print and on video.
And one more thing. This relates to nothing, but it's kinda fun. Check this out:
1000 is a thousand
1000000 is a million
1000000000 is a trillion
1000000000000 is a quadrillion
1000000000000000 is a quintillion
1000000000000000000 is a sextillion
Anything between that and infinity is a zillion.
I wanted to clarify the actual quantity of the number "zillion". Just trying to be helpful.
Re: 2A3 Upgrade (Paramour) [message #10650 is a reply to message #10559] Sun, 18 July 2004 07:42 Go to previous messageGo to next message
FredT300B is currently offline  FredT300B
The Paramours are a great product for the money, but they are a "budget" entry level amp whose parts have been speced to satisfy a relatively low price point. In my mind this raises a question about how much money one would want to spend upgrading Paramours versus starting over with a more upscale product like the Paraglow or a Welborne DRD 2A3 amp. Each upgrade to the Paramours is only an incremental expense, but you could increment yourself to something that ultimately costs more than it's worth. I did the Bottlehead iron and caps upgrade, which is well worth the price, and upgraded to a Sovtek 2A3 (you really should have a backup pair of power tubes anyway). Beyond this I believe I would try to find a buyer for the Paramours and replace them with a Paraglow or a DRD.
Re: 2A3 Upgrade (Paramour) [message #10729 is a reply to message #10572] Wed, 15 September 2004 00:46 Go to previous messageGo to next message
It's been a few months now and my Electro-Harmonix 2A3's have a few hundred hours on 'em now. You're right - They've picked up that blue glow. Just wanted to check back in with you and let you know. I still remember you're the one that recommended these tubes, and a good recommendation it was too. Thanks.
Iron, Push Pull [message #10900 is a reply to message #10568] Sun, 19 December 2004 17:40 Go to previous messageGo to next message
Hey-Hey!!!,
You don't need any particular type of Iron. Stay class A, choke input PS, and no 'lytics. Of course good Iron helps a lot...
You are looking at the last amp I have assembeled/designed. Part of the Iron is salvaged from one sort of PS or another. Outputs are Heyboer's copies of the Peerless S265 with a few mods for this particular circuit. The finals are HY69's, a Thoriated Tungsten DHTetrode. The front end is an E-Linear cascode diff amp. Ec2 referenced to the cathode node instead of the usual ground through a voltage divider...
It makes about 15 watts.
regards,
Douglas
....damn Thrintun!
E-Linear [message #10901 is a reply to message #10900] Sun, 19 December 2004 17:43 Go to previous message
and this is an example of an E-linear amp's circuit. No loop NFB. Single B+ supply.
It is the only thing I can think of that resembles a new valve circuit. If anybody can find me an example which resembles this, I would be very grateful.
regards,
Douglas
Previous Topic: tube sources needed
Next Topic: possible group build
Current Time: Sun Apr 28 16:11:57 CDT 2024
