Home » xyzzy » Tower » Air Handler Noise
Air Handler Noise [message #77312] Mon, 29 July 2013 10:14 Go to next message
Sometimes the indoor air handler of my central air conditioning unit emits a very high-pitched, low volume hum. I can't figure out a pattern to it as I only notice it occasionally. Do you think it's something I should be worried about?
Re: Air Handler Noise [message #77320 is a reply to message #77312] Mon, 29 July 2013 14:08 Go to previous messageGo to next message
Hi, Only if it interferes with serious stereo listening. Laughing
Depending on what it is there could be issues. HVAC systems tend to make various noises all the time. Often nothing to be worried about. If the unit gets noisier or does it more often then I would consider getting it checked out.
Re: Air Handler Noise [message #77338 is a reply to message #77312] Tue, 30 July 2013 16:18 Go to previous messageGo to next message
RustyC is currently offline  RustyC
Also, it will make a difference if you are the only one who can hear it. Laughing
I'm sorry. Aren't we a bunch of smart uh, donkeys, on here!
Probably it's nothing. But be smart. Pay attention if it gets louder or more frequent.
If you can isolate exactly where the noise is coming from, that might help. It could be as simple as air squeezing through some place that's not tightly sealed.
Re: Air Handler Noise [message #77360 is a reply to message #77312] Wed, 31 July 2013 10:00 Go to previous message
Yes, you guys are super helpful. Razz
I've only heard it a couple times. It sounds electrical rather than whistling air. I'll just keep an eye on it for now in case it gets worse or more frequent, as you suggested.
Previous Topic: Traveling the USA
Next Topic: Artwork
Current Time: Wed Nov 04 03:29:54 CST 2026
