Home » Audio » Thermionic Emissions » cheap kits for tube amps
cheap kits for tube amps [message #10510] Thu, 15 January 2004 08:00 Go to next message
Try "Gabes Tube Amplifiers and Stuff", he makes a SE 6watt from a 6sl7 tube rectified for 549$ and a 300b with tubes SE for 700$ as well as some pre-amps etc. interesting.
Re: cheap kits for tube amps [message #10511 is a reply to message #10510] Thu, 15 January 2004 09:45 Go to previous messageGo to next message
Is this the page you're referring?
It's a very interesting site. I see he's into old tube radios - That's cool. I like hangin' out on the Tube Radio forum 'cause I'm into old tube radios too.
Re: cheap kits for tube amps [message #10512 is a reply to message #10511] Thu, 15 January 2004 11:13 Go to previous messageGo to next message
Yes thats the guy, I like that old Mag 1515 which he claims is based on an old Magnavox tube radio. The schematic is real simple. Did you see the new 6L6 SE amp he writes about? 6sL7 driver tubes,0 NFB. There is a great design tutorial along with it where he explains all of his design descisions.
Re: cheap kits for tube amps [message #10513 is a reply to message #10512] Thu, 15 January 2004 14:13 Go to previous messageGo to next message
This one?
I saw that, and it looked real nice. Clean look, and from the description it sounds like it probably works well. For $550.00 for the kit, a person sure can't get hurt to give it a try!
I'll definitely check that one out, when the schedule permits. I'm still waiting for my Seduction kit, and I've got a "to-do" list about two years long. But that 606 kit sure looks interesting...
Re: cheap kits for tube amps [message #10514 is a reply to message #10513] Thu, 15 January 2004 15:07 Go to previous message
That looks like it but if you look under the projects page listing for "real simple and cheap 45/2a3 set", he gives an account of the design process that might have been an ealier iteration of that amp. There is a sidebar within that tutorial called 6L6 SE, just click on that. Very good info for begginners anyone reading this.
Previous Topic: OK lets try this one: any Schematic for an amp...
Next Topic: Tube Car Audio
Current Time: Mon Oct 26 19:20:00 CDT 2026
