Home » Audio » Speaker » Earbud Cover Falling Off
Earbud Cover Falling Off [message #76877] Tue, 28 May 2013 08:13 Go to next message
The soft cover over my right earbud keeps falling off for some reason and I have to keep pulling it back over the earbud. It's not easy and it's annoying to have to repeatedly do it. The other earbud is fine, so I'm not sure why it's doing that.
Re: Earbud Cover Falling Off [message #76932 is a reply to message #76877] Mon, 03 June 2013 13:44 Go to previous messageGo to next message
Maybe apply some tiny dabs of superglue to the piece that keeps falling off? Sounds like it was made just a tad too big. These things happen.
Re: Earbud Cover Falling Off [message #77077 is a reply to message #76877] Wed, 26 June 2013 05:49 Go to previous messageGo to next message
I think Kingfish's suggestion is good, as long as you make sure the glue doesn't cover any speaker holes. Maybe you can dab the superglue on right under the edge of the cover.
Re: Earbud Cover Falling Off [message #77855 is a reply to message #76877] Sat, 14 September 2013 07:02 Go to previous messageGo to next message
nehal is currently offline  nehal
Well, $40 does sound like something JVC would do, but not making something comparable to a high end Sony. Looks like they're stepping up their game and that's good for everyone.
200-101 200-101
3102 3102
640-553 640-553
Re: Earbud Cover Falling Off [message #77988 is a reply to message #76877] Tue, 01 October 2013 13:43 Go to previous message
Fannie is currently offline  Fannie
I don't know how many earbuds I have gotten rid of because of the covers falling off. I finally resorted to the headphones that fit over the ear. I never thought of trying to use super glue.
Previous Topic: ProAc Tablette Speakers
Next Topic: Headphones for Teenager
Current Time: Sun Nov 08 04:10:10 CST 2026
