Home » Audio » General » Annoying Rattling Sound?
Annoying Rattling Sound? [message #76322] Tue, 16 April 2013 14:41 Go to next message
timron is currently offline  timron
Do any others here have a component stereo system and notice an annoying rattle ever so often when watching a movie or listening to music? I didn't notice this sound until we started using our new system but it's driving me crazy! I can't figure out what it is!
Re: Annoying Rattling Sound? [message #76323 is a reply to message #76322] Tue, 16 April 2013 15:38 Go to previous messageGo to next message
iLoveiPod is currently offline  iLoveiPod
I can't help but wonder if maybe your bass is set too high. Do you have a subwoofer with adjustable bass, or adjustable bass/treble settings on the receiver?
Re: Annoying Rattling Sound? [message #76325 is a reply to message #76322] Tue, 16 April 2013 19:29 Go to previous messageGo to next message
Chicken is currently offline  Chicken
Is there anything on or near the subwoofer? If so, the sound energy could be causing it to vibrate. You should also check to see if your subwoofer has feet that may need to be tightened, or a cable coming out of the jack.
Re: Annoying Rattling Sound? [message #76344 is a reply to message #76322] Wed, 17 April 2013 19:37 Go to previous messageGo to next message
Kenwoody is currently offline  Kenwoody
We had a similar problem when we first set our stereo system up in the living room. Turned out in was because the subwoofer was sitting up under a glass and metal table and the bass was causing the glass to rattle in the metal seating. Maybe something like that is what's going on in your case. Might have something to do with where your subwoofer or other speakers are sitting.
Re: Annoying Rattling Sound? [message #76411 is a reply to message #76322] Sun, 21 April 2013 05:45 Go to previous messageGo to next message
It probably is something simple like the things others are pointing out. Glass tables nearby will also make that sound if the bass is too high.
Re: Annoying Rattling Sound? [message #76520 is a reply to message #76322] Fri, 26 April 2013 19:48 Go to previous message
Check where your A.C. is plugged in, I've seen where refrigerators, heaters, dryers etc. on the same circuit along with the audio equipment can cause problems.
Previous Topic: New York Audio Show
Next Topic: USB Cable with Separate Audio & Power
Current Time: Thu May 16 18:19:45 CDT 2024
