Home » Audio » Speaker » Woofer to partner Lowther in Sousahorn (98dB/w/m alnico Lowther in 160hz horn)
Woofer to partner Lowther in Sousahorn [message #76237] Mon, 08 April 2013 20:58 Go to next message
DRCope is currently offline  DRCope
I'm putting PM2As (16 ohm, 98dB/w/m, silver voice coil, alnico magnet) in 160hz horns and need a woofer to partner with it. I'm thinking probably horn loaded as I'd like to use a passive crossover and would prefer to keep it first order. It'll also need speed to keep up with the Lowther.
Thoughts? Suggestions?
Thanks!
Re: Woofer to partner Lowther in Sousahorn [message #76239 is a reply to message #76237] Mon, 08 April 2013 21:07 Go to previous message
Might use something like a LaScala bass bin?
I always thought those looked real cool, and they'd be fine up to that range.
Previous Topic: Multi Room Setups
Next Topic: Subwoofers
Current Time: Sun Apr 28 19:28:34 CDT 2024
