Home » Audio » Silicon Valley » Has someone tried using two Sonic Impact amps?
Has someone tried using two Sonic Impact amps? [message #10310] Fri, 15 April 2005 14:01 Go to next message
Pete Whitley is currently offline  Pete Whitley
One for each channel?
Thanks,
Pete
Re: Has someone tried using two Sonic Impact amps? [message #10311 is a reply to message #10310] Fri, 15 April 2005 19:32 Go to previous messageGo to next message
How would you do that; or do you mean one for lows and one for highs?
Re: Has someone tried using two Sonic Impact amps? [message #10312 is a reply to message #10311] Fri, 15 April 2005 20:02 Go to previous messageGo to next message
One for the right speakers, one for the left. I know they aren't monoblocks and you would not get more power but I'm thinking better soundstage, etc.
Re: Has someone tried using two Sonic Impact amps? [message #10313 is a reply to message #10312] Sat, 16 April 2005 10:27 Go to previous messageGo to next message
How would you bridge them? Or do you mean just use one channel?
Re: Has someone tried using two Sonic Impact amps? [message #10314 is a reply to message #10313] Sat, 16 April 2005 10:55 Go to previous messageGo to next message
Hi,
I mean just use one Sonic Impact amp per channel(speaker). They have volume controls so no preamp needed. I'm thinking the seperate power supplies, etc. will make the presentation better, maybe not. Very simple to do, no crossover or pre neccessary. I'm sure many have done this. I just got back from Radio Shack and bought another 12 volt ps and two mini to rca connectors so I'll give it a whirl later today.
You have heard of the Clari-T amp. Check this one out.
http://www.michael.mardis.com/sonic/start.html
Pete
Re: Has someone tried using two Sonic Impact amps? [message #10315 is a reply to message #10314] Sun, 17 April 2005 06:39 Go to previous messageGo to next message
Thanks for the link; try The Company Store also, they have a great 40 watt GC kit on their site.
Re: Has someone tried using two Sonic Impact amps? [message #10318 is a reply to message #10315] Thu, 28 April 2005 15:03 Go to previous messageGo to next message
lon is currently offline  lon
I saw some nice pillows at The Company Store.
They used to sell Ovaltine too.
Re: Has someone tried using two Sonic Impact amps? [message #10345 is a reply to message #10314] Sun, 30 October 2005 16:54 Go to previous messageGo to next message
LineArrayNut is currently offline  LineArrayNut
You can safely parallel them mono, but NOT bridge them mono. Sounds different, not quite as good, and did not fix the thermalling problem. If you want more info there's a thread on AA.
Re: Has someone tried using two Sonic Impact amps? YEP! [message #10346 is a reply to message #10310] Sun, 30 October 2005 17:01 Go to previous messageGo to next message
http://db.audioasylum.com/cgi/m.mpl?forum=amp&n=74712&highlight=LineArrayNut&r=&session=
no clue how taco hell got in that hyperlink, lol [message #10347 is a reply to message #10346] Sun, 30 October 2005 17:12 Go to previous messageGo to previous message
http://db.audioasylum.com/cgi/t.mpl?f=amp&m=74712
Previous Topic: Anyone using an Assemblage ST-40?
Next Topic: DIY Digital Amp Kits
Current Time: Sun Oct 18 08:06:52 CDT 2026
