Thanks, Wayne,
I went with the conventional way because I wanted to try out my new mini drill press before I have to pack it up. I'm also an old dog, so...
I think I will use little mini wood standoffs, glued into the cab, then I'll screw the board onto that.
Wayne Parham Messages: 18680 Registered: January 2001
Should work very nicely, I think. Just make sure you have enough support, especially under the coils. Might add extra wood supports or cushion with rubber supports in-between mounting holes and under heavy components.
