Home » Sponsored » Pi Speakers » Horn Midrange Enclosure
Horn Midrange Enclosure [message #75439] Mon, 04 February 2013 15:49 Go to next message
The 6/7Pi midhorn enclosure requires a removable back panel for installation and access to the driver. The panel in my build is attached with a dozen or so pocket screws around the periphery and two short damped braces extending from the driver magnet assembly to the panel. The result seems fairly solid, but there is still a fair amount of resonance at some frequencies with high level tone sweeps compared with the other walls of the enclosure. Are there any better alternatives to attaching and/or damping the panel?
Re: Horn Midrange Enclosure [message #75440 is a reply to message #75439] Mon, 04 February 2013 16:21 Go to previous message
Oh, yes, see the "Midhorn Bracing" link in the Miscellaneous section of the FAQ. That shows what we do for bracing. Simple and effective - You can add it right away. And you might find the "Finishing details for π cornerhorns" link useful too.
Previous Topic: Ground Plane Measurement
Next Topic: 12Pi plans please
Current Time: Fri Apr 26 19:12:50 CDT 2024
