Home » Sponsored » Pi Speakers » Ground Plane Measurement
Ground Plane Measurement [message #75428] Sun, 03 February 2013 12:23 Go to next message
I got rusty about ground plane measurements, opened up the D'Appolito book, and became clueless.
Are gp measurements comparable to anechoic or free field measurements, let's say if they are done out doors? I realize there are some effects, namely a virtual mirrored source which increases the gain. Assuming that is a 6 dB boost, if it is known it's not an issue. So will the frequency response be close to an anechoic measurement? Isn't that why we are doing a gp measurement to begin with?
I was looking at Wayne's 3PI sub FR graph, which is a gp measurement. I was thinking the 6 dB drop in FR in the octave
40-20Hz would be filled in, typically, by room gain (not considering other room effects.)
So is a gp measurement in this frequency range treated as if it were anechoic, apart from SPL?
Re: Ground Plane Measurement [message #75429 is a reply to message #75428] Sun, 03 February 2013 12:43 Go to previous messageGo to next message
Ground plane measurements are essentially the same as halfspace, except they show baffle effects whereas halfspace measurements don't. As the baffle begins to have an effect on directivity, this will show up in the ground plane measurement as rising response, sometimes with slight ripple at the onset. Halfspace can't show this because it is essentially an infinite baffle measurement.
Re: Ground Plane Measurement [message #75431 is a reply to message #75429] Sun, 03 February 2013 21:05 Go to previous message
Thanks, Wayne, it's much clearer to me as to the benefits of this type of measurement.
Previous Topic: Surround voicing and matching the mains
Next Topic: Horn Midrange Enclosure
Current Time: Thu Mar 28 04:52:30 CDT 2024
