Home » Sponsored » Pi Speakers » Factory refurbished JBL 2226H (Possible disavantages of purchasing refurbished woofer)
Factory refurbished JBL 2226H [message #75201] Thu, 10 January 2013 13:17 Go to next message
ice963 is currently offline  ice963
There are some factory refirbished JBL 2226H woofers for sale for $450. The advantage is the price but what could be the downside of getting them? They are reconed but does JBL check the voice coils ect. before sending them out?
Re: Factory refurbished JBL 2226H [message #75203 is a reply to message #75201] Thu, 10 January 2013 13:22 Go to previous messageGo to next message
Refurbished JBL Pro woofers are 100% as good as new, provided the basket is in good shape and the recone kit used is a genuine JBL part.
Re: Factory refurbished JBL 2226H [message #75208 is a reply to message #75201] Fri, 11 January 2013 01:19 Go to previous messageGo to next message
thatsnasty is currently offline  thatsnasty
As Wayne said, recones are as good as the originals, but I have no idea how you would tell its a genuine JBL, without measuring (or having a trustworthy source).
$450 each is a bit expensive for re-cones. You can find them brand new for around there.
I picked up mine from Ebay at under $200 a pop. They are all original cones (one is a 2226HPL). You can tell originals by the back of the cone having drips, and the dustcap having perfectly symmetrical "bunny ears", where the 2 leads are punched in the center.
Re: Factory refurbished JBL 2226H [message #75210 is a reply to message #75208] Fri, 11 January 2013 08:05 Go to previous message
They're $450 for the pair still in the box from JBL so I guess I'll jump on them and order the rest of the parts from Wayne. Thanks for the response.
Previous Topic: Tools get old as well
Next Topic: 2Pi Coil across woofer?
Current Time: Mon Nov 23 12:23:49 CST 2026
