Home » Sponsored » Pi Speakers » 7 Pi at bay window corner
7 Pi at bay window corner [message #74973] Sun, 16 December 2012 18:09 Go to next message
yscai is currently offline  yscai
I am interested in the 7 Pi speaker, but I only have a bay window corner can put it (a cut-cornered right angle corner). Will the arrangement affect the sound?
Re: 7 Pi at bay window corner [message #74976 is a reply to message #74973] Sun, 16 December 2012 19:41 Go to previous messageGo to next message
If the window, frame and surrounding structure don't rattle, it will be fine. The biggest problem is windows that are able to slide open usually vibrate in their tracks (and make a buzzing sound). So make sure that doesn't happen and if there's no rattle, you're set.
Re: 7 Pi at bay window corner [message #74977 is a reply to message #74973] Sun, 16 December 2012 21:07 Go to previous messageGo to next message
Great! Can you send me the Pi 7 plan?
Re: 7 Pi at bay window corner [message #74978 is a reply to message #74977] Sun, 16 December 2012 21:30 Go to previous message
You've got mail!
Previous Topic: 2Pi Tower Plans
Next Topic: Midrange horn shape in Pi cornerhorn
Current Time: Sat Apr 27 00:05:37 CDT 2024
