Home » Audio » Craftsmen » Altoids Amp.
Altoids Amp. [message #74782] Sat, 08 December 2012 02:47 Go to next message
srdmind is currently offline  srdmind
I have seen Altoids diy projects popping up all around the internet, and the other day I saw one about making a pocket amp for your headphones. What's your take on this?
Re: Altoids Amp. [message #75026 is a reply to message #74782] Wed, 19 December 2012 22:40 Go to previous messageGo to next message
They've been making the CMoy headamps in Altoids tins for a long time. They didn't start in the tins, but kind of went there for the novelty factor. The CMoy (named after the designer Chu Moy) sound surprisingly good for what they are. There are quite a few variations on the theme from different opamps for different sounds and even mini vacuum tube versions that will fit in a tin.
I've built several and I've never had anyone that's listened through them not like it more than just coming direct from the source. I think they are an excellent way to get your feet wet in the DIY headamp scene. It's almost a rite of passage.
Here's a link to some pics of the ones I've built.
http://www.rollinghillsimagery.com/Electronics/My-DIY-Equipment
Re: Altoids Amp. [message #80816 is a reply to message #74782] Tue, 11 November 2014 02:53 Go to previous message
RoseGul is currently offline  RoseGul
I would like to make some printed circuit boards. The only PCBs I have done were a long time ago where you used a pen to trace the circut over specially coated copper, then immersed the board in a solution to remove all the copper except where the lines were drawn.
Previous Topic: Affordable Parts Online
Next Topic: My DIY system
Current Time: Thu Nov 26 03:30:37 CST 2026
