Home » Sponsored » Pi Speakers » H290C dimensions (dimensions for the recessed cutout)
Re: H290C dimensions [message #73439 is a reply to message #73438] Tue, 31 July 2012 17:18 Go to previous messageGo to next message
zheka wrote on Tue, 31 July 2012 16:48
If I want to flush mount, should I use 1" MDF panel for the front baffle or 3/4" panel is adequate in your opinion? Given that the recess is 1/4" deep.
What I like cabinetmakers to do is to cut a ring that surrounds the baffle cutout both for the midwoofer and tweeter. This ring can be cut from scrap wood, and is only there to provide some extra thickness in the area where the router cuts into the baffle. Glue it in place behind the baffle, and install the T-Nuts or threaded inserts into it.
Re: H290C dimensions [message #73446 is a reply to message #73439] Wed, 01 August 2012 07:18 Go to previous messageGo to next message
Is it safe to assume that this kind of support rings do not require any cabinet volume compensation?
Re: H290C dimensions [message #73447 is a reply to message #73446] Wed, 01 August 2012 07:46 Go to previous messageGo to next message
That's right, no adjustment necessary. They don't displace much internal volume at all.
Re: H290C dimensions [message #74650 is a reply to message #73415] Thu, 29 November 2012 12:11 Go to previous messageGo to next message
Sorry to belabor this, but I want to be sure to get the baffle recesses right. In the H290C picture below, it looks like the corner radius is about the same height as the top and bottom flanges which are about 0.8", right?
index.php?t=getfile&id=931&private=0
Re: H290C dimensions [message #74651 is a reply to message #74650] Thu, 29 November 2012 12:33 Go to previous messageGo to next message
Yes, exactly. If you continue to rotate the curvature of the corner to form a full circle, it will have diameter of 1.6", e.g. radius of 0.8".
Re: H290C dimensions [message #74652 is a reply to message #74651] Thu, 29 November 2012 12:46 Go to previous message
Gotcha, thanks.
Previous Topic: Speaker placement and wavefront launch
Next Topic: Spectral decay time of HF drivers
Current Time: Tue Apr 16 06:44:26 CDT 2024
