Home » Audio » General » Cleaning Earbuds
Cleaning Earbuds [message #73213] Fri, 06 July 2012 08:14 Go to next message
How often do you clean your earbuds, and how do you do it? I wipe them after each use but that's really all I do. I'm not sure if I should be doing anything else.
Re: Cleaning Earbuds [message #73229 is a reply to message #73213] Mon, 09 July 2012 08:46 Go to previous messageGo to next message
Do you wipe them with a disinfecting agent or just a dry cloth? I put a little bit of a vinegar/water mixture on a cloth so it's damp but not wet and use that.
Re: Cleaning Earbuds [message #73233 is a reply to message #73213] Mon, 09 July 2012 12:20 Go to previous messageGo to next message
mixinlady
I only wipe mine off after I travel. If it's just me using them and they're not something that can make me sick, then I don't really see the point of cleaning them on a regular basis.
Re: Cleaning Earbuds [message #73250 is a reply to message #73213] Wed, 11 July 2012 21:18 Go to previous messageGo to next message
Equinom is currently offline  Equinom
I do not really clean mine, especially on a daily or weekly basis. I normally just wipe them down with a dry cloth. I wouldn't want to accidentally ruin them by using a wet or dampened cloth.
Re: Cleaning Earbuds [message #73281 is a reply to message #73213] Fri, 13 July 2012 21:18 Go to previous messageGo to next message
LuvMartin is currently offline  LuvMartin
I wipe mine down with an alcohol pad from time to time. Alcohol dries really fast so you don't really have to worry about them getting wet, and it kills any germs that might get in there.
Re: Cleaning Earbuds [message #73294 is a reply to message #73213] Mon, 16 July 2012 08:04 Go to previous message
Thanks for all the input. I really like the alcohol idea since it dries so quickly. I think I will start doing that on occasion.
Previous Topic: Hope everyone had a good 4th!!!
Next Topic: Ghosts & Audio
Current Time: Sat May 18 18:54:03 CDT 2024
