Home » Audio » General » Standing waves
Standing waves [message #73045] Tue, 19 June 2012 00:39 Go to next message
I know that standing waves are undesirable, but I don't really know what they are.
Would someone bring me up to speed?
Floyd
Re: Standing waves [message #73050 is a reply to message #73045] Tue, 19 June 2012 07:58 Go to previous messageGo to next message
From Physics.info:
Re: Standing waves [message #73055 is a reply to message #73045] Wed, 20 June 2012 07:47 Go to previous messageGo to next message
While this is mechanical rather than audio, the collapse of the Tacoma Narrows Bridge is a famous example of how standing waves and resonance can be destructive.
Re: Standing waves [message #73079 is a reply to message #73055] Thu, 21 June 2012 13:22 Go to previous messageGo to next message
Hi, There is a free fairly simple XL spread sheet available to use to calculate the nulls and peaks in a room. I have used it a number of times to avoid disastrous placement of speakers. If you will PM me with an email address I can send you a copy.
It won't fix anything... but can keep you from making mistakes in placement of speakers and your listening position. Unfortunately it does not have provisions for what happens if you use room treatments.
Re: Standing waves [message #73109 is a reply to message #73079] Sat, 23 June 2012 01:29 Go to previous message
Bruce,
Can I have a copy? It would help me gain a simple understanding of what the variables are.
Floyd
Previous Topic: Laptop Speakers
Next Topic: Some odd changes in sound level I've noticed.
Current Time: Sun Oct 18 00:06:40 CDT 2026
