Home » Audio » Thermionic Emissions » Marshall DSL100 Buzz
Marshall DSL100 Buzz [message #9859] Wed, 08 November 2006 21:09 Go to next message
Alex is currently offline  Alex
Hi
This probably isn't a biggie, just me worrying about my amp. My amp transformer buzzes when in use and it also comes through the speakers. I know transformers buzz, but i've never heard amp transformers buzz before, even if they're 100W all tube amps... Is this anything to worry about, or is it all good?
Re: Marshall DSL100 Buzz [message #9863 is a reply to message #9859] Thu, 09 November 2006 22:21 Go to previous messageGo to next message
Did it just start? If the buzz in the speaker has not changed and nothing seems to be too hot (can you hold your hand on the transformer and count to ten?) If so, then I won’t say, "it’s all good" but your probably OK…John
Re: Marshall DSL100 Buzz [message #9864 is a reply to message #9863] Sun, 12 November 2006 21:39 Go to previous message
I got the tranformer rewound cause i brought it in from another country. So its always been doing it.
Previous Topic: Darling 1626 PS suggestions--first design.
Next Topic: 6Ah4 Amp
Current Time: Fri Oct 23 06:12:24 CDT 2026
