Home » Sponsored » Pi Speakers » Clamp Rack
Clamp Rack [message #72818] Fri, 25 May 2012 16:42 Go to next message
This was so easy. Why did I wait so long to get the clamps off the floor and out of the corners?
First, I needed a crosscut sled because the miter gauge that came with my cheap-ass tablesaw sucks. Second, I thought I needed a dado set for the saw. Second, Part B, w/o a dado set I'd have to make numerous passes with the standard blade to cut the kerfs.
Well, retirement's main virtue is time and it's evil counterpart vice, empty time. I had time to fill so I made the sled this A.M. and found a website that showed drilling a hole at the back of the kerf which means only 2 saw passes per. Why didn't I think of that?
Ecco! Clamps on the wall before lunch!
index.php?t=getfile&id=785&private=0
Re: Clamp Rack [message #72819 is a reply to message #72818] Fri, 25 May 2012 18:28 Go to previous messageGo to next message
Now that's the right way to do it!
Re: Clamp Rack [message #72827 is a reply to message #72818] Sat, 26 May 2012 05:24 Go to previous messageGo to next message
You need a project. Laughing
Re: Clamp Rack [message #72828 is a reply to message #72827] Sat, 26 May 2012 07:12 Go to previous messageGo to next message
Nick77 wrote on Sat, 26 May 2012 06:24
Just finishing one, waiting for the Cinemag transformers to arrive.
index.php?t=getfile&id=786&private=0
Will start construction of the 2Pi Towers when I get back from Ribfest next week
icon14.gif  Re: Clamp Rack [message #72911 is a reply to message #72819] Mon, 04 June 2012 10:46 Go to previous message
mgalusha is currently offline  mgalusha
Nice, been trying to figure out a good way to store the clamps, that is nice and tidy.
Mike G.
Previous Topic: Wood used in 4PI construction
Next Topic: would these work with the 3pi design?
Current Time: Tue Oct 20 09:15:23 CDT 2026
