Home » Sponsored » Pi Speakers » 3Pi Subwoofer
3Pi Subwoofer [message #72637] Wed, 09 May 2012 07:34 Go to next message
What's included in the kit?
Re: 3Pi Subwoofer [message #72638 is a reply to message #72637] Wed, 09 May 2012 09:51 Go to previous messageGo to next message
The woofer, the port, a cable assembly with the connector panel, the logo decal and a printed copy of the plans.
Re: 3Pi Subwoofer [message #72641 is a reply to message #72638] Wed, 09 May 2012 12:58 Go to previous messageGo to next message
The woofer is your OEM version of the Lab 12?
What amp are you using? Internal plate or something else?
Low level from the pre-amp or high?
Re: 3Pi Subwoofer [message #72643 is a reply to message #72641] Wed, 09 May 2012 13:42 Go to previous messageGo to next message
Yes, it's my PI-12 woofer, an OEM version of the LAB12 machined to fit the cooling plug. For the three Pi subs, you could use either driver just as well.
I'm using a pair of those Selectronic 50W Class-A FET amps. Plate amps work great too, and are probably more convenient 'cause they bolt on the back.
I use my little passive preamp - that remote control circuit I made for the DIY and kit amp crowd - and split off the outputs to the amp for the mains and to the crossover for the subs.
Re: 3Pi Subwoofer [message #74604 is a reply to message #72643] Mon, 26 November 2012 20:00 Go to previous messageGo to next message
timkur is currently offline  timkur
So 50W is sufficient for these subs.
I'm assuming then that something like this...
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-807
(500W Plate Amp)
would be complete overkill?
Thanks
Tim
Re: 3Pi Subwoofer [message #74606 is a reply to message #74604] Mon, 26 November 2012 21:35 Go to previous message
That's a great size amp for subs like these. I run a 50 watt amp and it's plenty, but naturally it leaves a lot on the table, unused. They'll take a lot more than that.
Previous Topic: L/C/R placement and toe-in
Next Topic: Which Pi for me?
Current Time: Sun Apr 28 20:47:03 CDT 2024
