Home » Sponsored » Pi Speakers » Off-the-shelf 4 Pi Stand
Off-the-shelf 4 Pi Stand [message #72386] Wed, 25 April 2012 15:59 Go to next message
jdubs is currently offline  jdubs
Hey all
How about this for an off-the-shelf solution?:
http://www.standsandmounts.com/vtirfseries13inchcenterchannelspeakerstandrfc.aspx
The right height (13") and it has an inbuilt 6 degree tilt. Looks pretty good to me but I'd love to hear any other thoughts.
-Jim
Re: Off-the-shelf 4 Pi Stand [message #72387 is a reply to message #72386] Wed, 25 April 2012 18:18 Go to previous message
That looks like it would work just fine. If you get a set of those, report back how they work for you.
I use wood stands with the top plate pretty close in size to the cabinet size. The back edge has a lip that cradles the speaker. I also use rubber underneath to grip the speaker. Between the rear lip and the rubber underneath, the speaker is planted nicely and doesn't move.
Previous Topic: My Finished 4pi (x2)
Next Topic: Pi 7 Information
Current Time: Tue Oct 20 17:15:36 CDT 2026
