Home » Sponsored » Pi Speakers » Where's the Voice Coil?
Where's the Voice Coil? [message #71915] Mon, 26 March 2012 06:09 Go to next message
I'm looking at an Alpha 10A and measure approx 2" from the spider to the front of the speaker frame.
Is it reasonable to assume that the spider is roughly centered on the coil and it's about 1 1/2" to the front?
Re: Where's the Voice Coil? [message #71916 is a reply to message #71915] Mon, 26 March 2012 08:03 Go to previous messageGo to next message
The voice coil is centered just behind the front plate. That's the physical center, but the acoustic center depends on a lot of stuff. So if that's what you're really wanting to know, you gotta measure it. But you can estimate it as being just behind the front plate.
Re: Where's the Voice Coil? [message #71918 is a reply to message #71916] Mon, 26 March 2012 08:28 Go to previous messageGo to next message
Measuring at greater distances to lessen the effect of the acoustic center seems to imply that by the time the wavefronts reach the listening position time delay of the drivers becomes moot?
Couldn't hurt to try and line up the voice coils, tho'?
Re: Where's the Voice Coil? [message #71920 is a reply to message #71918] Mon, 26 March 2012 10:09 Go to previous message
Measurements at a large distance make small shifts in acoustic center have less effect on SPL, but they don't change the effects on phase. If you have two sound sources that are a half-wavelength apart, you'll still have cancellation, no matter what distance they're at. So distance won't help with that. But if the goal is to get accurate measurements of SPL, then measuring at a distance helps, because it makes the smal shifts in acoustic center less relevant. For example, if the acoustic center is one meter behind the face and you measure one meter from the face, then you have actually measured two meters from the source. But if you measure ten meters from the face, then that's eleven meters from the source. One is a factor of 2.0-to-1.0, the other a factor of 1.1-to-1.0. See the difference?
Previous Topic: Corner bracing 4pi
Next Topic: Piece of Aluminum Offboard? What's that?
Current Time: Sat Apr 27 07:20:46 CDT 2024
