Home » Sponsored » Pi Speakers » Center Channel with 6pi Corner Horns
Center Channel with 6pi Corner Horns [message #71742] Tue, 13 March 2012 15:49 Go to next message
Having just acquired a Sherwood R-972 receiver with the Trinnov room correction, the need for a quality center channel has arisen. The front right and left speakers will be 6pi corner horns. An upgraded 3pi is a consideration; however, the standard 3pi cabinet is several inches too tall and would require modification. Any other suggestions for a quality solution.
Re: Center Channel with 6pi Corner Horns [message #71745 is a reply to message #71742] Tue, 13 March 2012 16:32 Go to previous message
I would use a three π center speaker because it is a good spectral match.
Previous Topic: 4Pi Plans
Next Topic: H290 bumps / texture inside of horn - ok to sand down to smooth?
Current Time: Sat Apr 27 07:19:47 CDT 2024
