Home » Sponsored » Pi Speakers » 8 Pi Crossover questions
8 Pi Crossover questions [message #70305] Sat, 26 November 2011 18:26 Go to next message
svinzant is currently offline  svinzant
Wayne,
I have been studying the 8Pi plans and have a few questions about the crossover.
1/ I see that you have L1 listed as 1.0uF. Should it be 1.0 mH?
2/ Based on the layout of your circuit board, I don't see how L4 can connect to the junction of R4, R5 and the Mid-Woofer "+". (I spoze it could connect to the top of C5a. Comments?
3/ I see you spec the wattage of R2 at 10 Watts non inductive, but did not spec out the wattage for R1, R4 and R5, what should they be?
4/ Does the 8 Pi use a Zobel circuit?
5/ The schematic lists L2, but that is no inductor in the drawing. Is it just shorted with a jumper?
Thanks and sorry for all the noob questions.
Scott
Re: 8 Pi Crossover questions [message #70306 is a reply to message #70305] Sat, 26 November 2011 21:38 Go to previous messageGo to next message
Answers by numbers:
1. L1 is 1.0mH.
2. We jumber the 3+ pad to the 2+ pad. The L4 coil essentially bypasses the R4/R5 divider circuit that feeds the midwoofer.
3. All resistors are 10 watt non-inductive parts.
4. R4 and R5 provide the proper amount of damping, which is also what zobel does.
5. L2 is a jumper. Note also that there is no L3. The L3 and R4 positions are shared. Some crossovers use L3 and others use R4 but none use both.
[More] 8 Pi Crossover questions [message #70308 is a reply to message #70306] Sun, 27 November 2011 10:53 Go to previous messageGo to next message
Wayne,
Thanks for the quick reply.
This has generated a few more questions...
I have read thru parts of the "Speaker Crossover Document" and based on my limited understanding (at this point) it seems like the crossover for the 8 Pi is a "Pseudo First Order" filter for the mid-woofer. I am basing that on the fact that I don't see a capacitor in the schematic for the woofer section.
The tweeter filter section seems to be a set up as a Third Order Butterworth filter.
If I am off base on these, please straighten me out a bit.
Additionally, based on other things I have gathered from reading here and at other sites, should the value of L4 be .5mH?
You have it shown on the schematic as 5mH (no decimal point).
Thanks again for the great resources!
Scott
Re: [More] 8 Pi Crossover questions [message #70312 is a reply to message #70308] Sun, 27 November 2011 17:02 Go to previous messageGo to next message
No, it should be 5mH. It's a gentle filter that does have approximately a first-order slope, but it isn't a crossover, it's essentially EQ. The midhorn increases efficiency at midrange frequencies, but not bass. So the whole L1/R4/R5 network is a response shapong network.
As an aside, pseudo-first-order is just a name I gave to single-component crossovers without a Zobel. I sometimes also refer to them as pseudo-Butterworth networks. All I really mean by that is a reminder that the filter isn't pure first-order unless the load is resistive - which it isn't. So it looks like a first-order filter, but isn't really. It usually forms a first-order slope down low, but more of a shelved response up high. It cannot maintain 6dB/octave through the whole band because the load impedance changes with frequency.
Re: 8 Pi Crossover questions [message #70487 is a reply to message #70305] Sat, 17 December 2011 18:01 Go to previous messageGo to next message
jhovis is currently offline  jhovis
so the 8Pi now has a crossover? I bought a kit 5-6 yrs ago and it has been in my basement. It only came with the drivers and a horn and maybe a capacitor. I was thinking about putting it together, but I know I don't have crossover parts.
Re: 8 Pi Crossover questions [message #70489 is a reply to message #70487] Sat, 17 December 2011 19:25 Go to previous messageGo to next message
It definitely came with a crossover. Look closely, as it would have come with a printed circuit board and some cable assemblies.
Back then, the tweeter cable assemblies had the R1/R2/C1 components built into the cable. All the other parts were on the printed circuit board.
Now days, all the parts are in the crossover board, and the cable assemblies are just wire.
Re: 8 Pi Crossover questions [message #70603 is a reply to message #70489] Fri, 23 December 2011 15:41 Go to previous message
My apologies Wayne, you were correct. I dug out the box-o-parts and there is a crossover in there. Someday, I'll get around to building it. Laughing
Previous Topic: Flush mount
Next Topic: 2Pi Tower questions
Current Time: Wed May 08 20:28:52 CDT 2024
