Home » Sponsored » Pi Speakers » Top portion of the 8Pi (Would like to know if its possible to add the compression portion to a pair of )
Top portion of the 8Pi [message #70102] Fri, 11 November 2011 21:56 Go to next message
Bemopti123 is currently offline  Bemopti123
Onken cabinets loaded with a 10" Vifa driver, running fullrange. There is no way for me to know what is the upper cut off frequency of my Onken cabs, all that I know is that it was built to work properly with the BD Oris 200 horns which use a 200HZ cut off.
I would ideally biamp this set up, with the Oris running fullrange on top, and the bottom would be biamped to a NHT X-2 crossover which would handle the bottoms up to 250 HZ.
Is this set up even possible?
Re: Top portion of the 8Pi [message #70104 is a reply to message #70102] Fri, 11 November 2011 23:37 Go to previous message
Might be. But sorry, without more information it's hard to know how well it will work. You really have to roll up your sleeves, make some models and some measurements, and see what you've got.
Previous Topic: 6PI vs 7PI
Next Topic: 4Pi
Current Time: Thu May 09 06:59:22 CDT 2024
