Home » Sponsored » Pi Speakers » One- Pi crossover tweeking. ( upper midrange forwardness.)
One- Pi crossover tweeking. [message #69799] Wed, 12 October 2011 16:58 Go to next message
With the one Pis close to the floor the tone sounded perfect but when raised up over 10 inches the upper mid range sounded a little forward used with solid state receivers. So changed the crossover capacitor to 8.2uf with great results. First tested in 1.0 cu ft. box tuned to 60.0 hz plus or minus. Tested in two different locations. It may be just my ears.
Re: One- Pi crossover tweeking. [message #69801 is a reply to message #69799] Wed, 12 October 2011 19:13 Go to previous message
Yeah, it's definietly better when placed close to boundaries. They work well as surrounds when hung from the wall or set on bookshelves. But if you're using them as mains on stands, you should definitely be running subs with them. That's good advice for any two-way speaker on a stand.
Previous Topic: 7pi cabinet plan request
Next Topic: AE Drivers
Current Time: Thu Nov 12 03:09:44 CST 2026
