Home » Audio » Speaker » Multi sub hook-up question (3 sub hook up)
Multi sub hook-up question [message #69572] Thu, 22 September 2011 17:05 Go to next message
watchmego is currently offline  watchmego
If I have an integrated amp that has A and B speaker connections can I hook two active subs up to the B posts speaker level and one sub up to the pre amp out line level?
Re: Multi sub hook-up question [message #69573 is a reply to message #69572] Thu, 22 September 2011 17:54 Go to previous message
No, you'll want to low-pass the subs, meaning you'll need some kind of crossover. For flanking subs (nearest the mains), you can use a simple coil in series, but this will only work if the subs are as close to the same sensitivity as the mains (which is unusual). This is impractical in most cases, so active crossovers are used instead.
Previous Topic: 3-Way Speakers for My Car
Next Topic: Passive Bi-Amplification
Current Time: Fri Nov 06 05:20:49 CST 2026
