Home » Audio » Room Acoustics » Soundproof Windows
Soundproof Windows [message #69540] Mon, 19 September 2011 06:43 Go to next message
Siren is currently offline  Siren
I am trying to reduce the outside noise, there is a highway outside my house, and I have already tried the soundproof curtains. I have been hearing about soundproof windows, and wondered if they are worth spending money on? Which brand is the best to buy?
Re: Soundproof Windows [message #69547 is a reply to message #69540] Mon, 19 September 2011 08:58 Go to previous messageGo to next message
Danny is currently offline  Danny
Soundproof curtains? I've never heard of those. I can't imagine that they would do any better than soundproof windows. If the noise is that bad, it just might be a good investment for you.
Re: Soundproof Windows [message #69559 is a reply to message #69547] Wed, 21 September 2011 08:46 Go to previous messageGo to next message
Christy is currently offline  Christy
Yes, they make soundproof curtains, which probably work better for someone who does not live near a highway. I think I will invest in the windows,too. I could use some feedback, also, to make sure it is worth it.
Re: Soundproof Windows [message #69594 is a reply to message #69559] Sat, 24 September 2011 07:56 Go to previous messageGo to next message
If the noise is bothering you so much that the curtains aren't helping enough, the windows will probably be worth it to you. I imagine that type of window may also be helpful with energy costs.
Re: Soundproof Windows [message #69933 is a reply to message #69594] Mon, 31 October 2011 08:49 Go to previous messageGo to next message
Kripes is currently offline  Kripes
We used to have wooden window frames with a single pane of glass until we invested in double glazing. It's a PVC frame with a double pane of thickened glass and it reduces outside noise considerably.
Re: Soundproof Windows [message #69934 is a reply to message #69540] Mon, 31 October 2011 19:56 Go to previous message
Drury is currently offline  Drury
I'm okay with noise, but when traffic makes things shake I find it a bigger nuisance. Creating some sort of second layer on the windows will definitely help with the former.
Previous Topic: Transforming basement to practice/recording space
Next Topic: What do you think about this Pi speaker layout?
Current Time: Fri Nov 13 20:11:19 CST 2026
