Home » Audio » Thermionic Emissions » Buying Amps on eBay
Buying Amps on eBay [message #69262] Thu, 01 September 2011 06:53 Go to next message
Chicken  is currently offline Chicken
Do you ever buy tube amps on eBay? How do you know they will sound ok? Do you just go by the brand name and specs?
Re: Buying Amps on eBay [message #69266 is a reply to message #69262 ] Thu, 01 September 2011 09:39 Go to previous messageGo to next message
Danny  is currently offline Danny
Well, first, you will go by the specs. And then you will make sure you are buying from a reputable seller. I have actually had good experiences from shopping on eBay.
Re: Buying Amps on eBay [message #69277 is a reply to message #69266 ] Thu, 01 September 2011 13:53 Go to previous messageGo to next message
gofar99  is currently offline gofar99
Hi Another good thing to do is check out the forums on the type and model of the amp. Some on Ebay are cheap and there is often a good reason for that. Confused
Re: Buying Amps on eBay [message #69289 is a reply to message #69262 ] Fri, 02 September 2011 07:14 Go to previous messageGo to next message
Well yes, I figured the specs would be one of the first things to look at, but I forgot to consider seller feedback. Can you tell I'm not on eBay often? Razz I just prefer to hear something in person before I buy, although forum feedback is good too.
Re: Buying Amps on eBay [message #70107 is a reply to message #69277 ] Sun, 13 November 2011 17:09 Go to previous messageGo to next message
I would have to say that I have had nothing but good luck with eBay. I just make sure the person has lots of good feedback before I buy something. I think there was only one time that I didn't receive something. It was coming from overseas. As soon as I questioned the seller, he promptly refunded my money.
Re: Buying Amps on eBay [message #70157 is a reply to message #70107 ] Tue, 15 November 2011 13:31 Go to previous messageGo to next message
Aki  is currently offline Aki
Bought everything from no-name 1940's PA amp to vintage McIntosh's on eBay.
Common sense prevails when buying things on eBay. In addition to the feedback checking, etc., I try to get the feel for the seller from the description. If the seller is into audio and knows the equipment, showing some pride of ownership, there likely won't be any issue.
On the other hand, it'll be a gamble buying from a seller who claims to have found that McIntosh MC275 in a cave somewhere, and has no knowledge of how to test it.
I have seen that gamble can payoff big time, but I'm not a gambling man....
Re: Buying Amps on eBay [message #70164 is a reply to message #70157 ] Tue, 15 November 2011 19:21 Go to previous messageGo to next message
Show me the way to the cave... Very Happy I agree, if the seller seems to understand the value and operational features of what he is selling then there is a good chance it is OK. Price is a good guide too, there are no pristine MC275s for $50.
Re: Buying Amps on eBay [message #72680 is a reply to message #69262 ] Fri, 11 May 2012 15:36 Go to previous messageGo to next message
likearecordbaby
Yes I've bought some there, and eBay can be a great source for getting them reasonably priced. Just be picky about your seller by looking at their feedback, what they claim the condition is, etc.
Re: Buying Amps on eBay [message #72717 is a reply to message #72680 ] Mon, 14 May 2012 16:52 Go to previous message
Hi Another problem with all types of sites is the reviews. A number of less honest ones Evil or Very Mad are writing their own "glowing" reviews.
Previous Topic:Tube Chess Set
Next Topic:EL156
Current Time: Fri Apr 20 09:32:19 CDT 2018
AudioKinesis
AudioKinesis
BuildAnAmp.com
BuildAnAmp.com
Crescendo Systems
Crescendo Systems
