4Pis are back and I wrote a BOOK! [message #69261] |
Thu, 01 September 2011 06:48 |
Bill Epstein
Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
Illuminati (2nd Degree) |
It was suggested to me that the Utah/S-B Acoustics 2-ways weren't imaging well (voices and instruments stuck to the speakers) due to beaming of the 12" woofer at the top of it's range. This was after I raised the crossover point from 2000 to 2800 Hz in hopes of improving the imaging, which didn't help, the opposite of the advice.
I'm going to try going far lower on the tweeter; it's Fs is 600 Hz so my next step is to build a 1200 Hz, 4th Order Link-Witz Riley crossover. Opinions on that???
Much as I like the tonal color of these 2-ways, replacing them yesterday with the 4Pis after about 3 months was a revelation. The last music I listened to before the switch was John Mayall and The Blues Breakers Featuring Eric Clapton. Everything about this original London sounded crisper and more dynamic.
A few days ago I received and played the Bjoerling/Corelli/Scotto Turandot on Angel. It sounded indistinct and far away, something I chalked up to the inferior reputation of the record label. I replayed it yesterday and, guess what? It sounded clear, punchy and dynamic but don't think for a minute that Puccini became John Philip Sousa; the bel cantoaspect of the music was even more bel canto!
I really want the Utahs to work out because I can hear beauty in them and I like the idea of a dynamic tweeter but right now, their flaws exceed their virtues. I'm not prepared to invest in the testing equipment and knowledge building it would take to realise a finished design so I guess I'll just Potz around with them. In between building the Theatre 4 Pis and these current to-the-letter 4Pis, I tried all sorts of variations of cabinets and drivers. No one knows better than I that when Wayne says you can't fool with the Pi parameters without extensive testing, you'd better listen. The 4Pis are just killer speakers: tone, texture, imaging, it's all there. Because it's a tested, finished design based on science and aesthetics.
Cone/dome two-way [message #69272 is a reply to message #69261] |
Thu, 01 September 2011 13:00 |
Messages: 18686 Registered: January 2001
I'd crossover at a lower frequency, but I'm not sure I'd go fourth-order, probably less, depending on what the tweeter could handle. You'll also probably want to make the woofer and tweeter crossover filters symmetrical, i.e. same frequency and slope. It's hard to know what slope to use and what frequency works best, definitely a balancing act. With matched-directivity two-ways, it's a little easier to know the general frequency range where crossover should happen, so the hard part is limited to getting the phasing right to make the best forward lobe. But with a garden-variety cone/dome speaker, we're not looking for a directivity match. As I said, it ends up being a balancing act of competing priorities.
What we're usually hoping for is best on-axis response and a generally wide pattern with fairly uniform off-axis response. Directivity won't be matched at the crossover point, but if power response is flat, then it usually sounds best. There are a few things to balance. Low-order slopes are usually good in terms of transients, and the wide overlap makes the directivities or the midwoofer and tweeter blend, sometimes making directivity actually pretty uniform. High-order slopes are usually better in terms of distortion and tweeter protection, but usually make transient response and directivity suffer. Likewise, a higher crossover usually easier on the tweeter, but directivity and consequently imaging aren't as good. A lower frequency crossover, especially with low-order slope is great for imaging, but greatly reduces power handling, increases distortion at moderate levels and ultimately usually kills dome tweeters. So it's kind of a balancing act.
Damping resistor across the tweeter! [message #69350 is a reply to message #69316] |
Tue, 06 September 2011 08:48 |
spkrman57
Messages: 522 Registered: May 2009
Illuminati (1st Degree) |
JBL did that with a lot of their MF/HF drivers in their crossovers to smooth out the impedance variations reflected back to the crossover.
Try a value that is 2 X the Dcr of the driver. The lower impedance of that scenario is not as much as you think it would be affected.
It might raise the crossover frequency to the HF just a bit, but not so much that you might notice.
Ron sends...
