Home » Sponsored » Pi Speakers » 1pi or 2pi for surrounds?
Re: 1pi or 2pi for surrounds? [message #69394 is a reply to message #68904] Thu, 08 September 2011 15:06 Go to previous messageGo to next message
smokarz is currently offline  smokarz
thanks wayne, that sounds a bit complicated.
guess i will stick with shellac and a can of poly spray.
Re: 1pi or 2pi for surrounds? [message #69437 is a reply to message #68904] Sat, 10 September 2011 11:39 Go to previous messageGo to next message
i know wayne loves pictures, so here goes.
cabs routed, trimmed, and sanded. ready for stain.
hopefully they will be ready to make some music in the next couple of days.
http://i992.photobucket.com/albums/af48/smokarz/speaker/DSC02409.jpg
http://i992.photobucket.com/albums/af48/smokarz/speaker/DSC02411.jpg
Re: 1pi or 2pi for surrounds? [message #69444 is a reply to message #69437] Sat, 10 September 2011 16:32 Go to previous messageGo to next message
Nice work! They look great!
Re: 1pi or 2pi for surrounds? [message #69466 is a reply to message #68904] Mon, 12 September 2011 21:57 Go to previous messageGo to next message
and finally, my finished 1pis.
http://i992.photobucket.com/albums/af48/smokarz/speaker/DSC02448.jpg
Re: 1pi or 2pi for surrounds? [message #69467 is a reply to message #68904] Mon, 12 September 2011 21:58 Go to previous messageGo to next message
back view....
http://i992.photobucket.com/albums/af48/smokarz/speaker/DSC02450.jpg
Re: 1pi or 2pi for surrounds? [message #69468 is a reply to message #68904] Mon, 12 September 2011 22:01 Go to previous messageGo to next message
haven't listen to these little ones yet. still waiting for the glue on the ports to dry overnight. i'll hook them up tomorrow.
Re: 1pi or 2pi for surrounds? [message #69470 is a reply to message #69468] Tue, 13 September 2011 09:36 Go to previous messageGo to next message
Hey those look great! How was it stuffing the insulation through the woofer cut out? Guess I am anal. I measured and cut my insulation then installed it before mounting the front(baffle) to make sure it fit as I wanted.
Re: 1pi or 2pi for surrounds? [message #69471 is a reply to message #68904] Tue, 13 September 2011 09:57 Go to previous messageGo to next message
thanks, yes i fit the r13 through the woofer cutout.
i am not much of a perfectionist. as long as there's adequate stuffing i think it will work just fine.
Re: 1pi or 2pi for surrounds? [message #69472 is a reply to message #69471] Tue, 13 September 2011 10:29 Go to previous messageGo to next message
The finish looks great. Is it spray on poly?
Re: 1pi or 2pi for surrounds? [message #69473 is a reply to message #68904] Tue, 13 September 2011 10:59 Go to previous messageGo to previous message
thanks wayne.
actually i skipped the poly, was a bit lazy, again i am pretty amateur when it comes to this stuff (this is my 3rd project).
i sanded the bb with 220 and 320 grits. applied a coat of clear shellac, sanded 400 grits. applied another coat of amber shellac, sanded 400 grits again. clean with mineral spirits and done.
Previous Topic: Flanking subs and phase
Next Topic: Pi 3 or 4?
Current Time: Sun Apr 28 01:49:29 CDT 2024
