Home » Audio » Source » Dynavector 10X5 Assist
Dynavector 10X5 Assist [message #68809] Mon, 01 August 2011 17:44 Go to next message
Hi Everyone, My favorite TT wasn't sound quite right so I went through all the checks and ultimately it pointed to the cartridge. When I looked at it under magnification (see photo) the cantilever is warped to one side. Not bent or kinked, just bowed. Anyone ever see this before? Also anyone know a good place to get it fixed?
index.php?t=getfile&id=565&private=0
  • Attachment: Image7.jpg
    (Size: 129.59KB, Downloaded 4010 times)
Re: Dynavector 10X5 Assist [message #68810 is a reply to message #68809] Mon, 01 August 2011 18:14 Go to previous messageGo to next message
I had an Audio Technica that was like this once. I was prepared to buy a new stylus, but thought I would try to true it up myself. Amazingly, I was able to bend it slightly without breaking it. Worked very well. Not sure that's the way it always goes, but for me, I was able to get the arm quite straight.
Re: Dynavector 10X5 Assist [message #68811 is a reply to message #68810] Mon, 01 August 2011 20:12 Go to previous messageGo to next message
Hi Wayne, I considered that, but I'm concerned that it may be twisted as well and it will gouge the LPs. Soundsmith seems to be a good bet, but ouch, Shocked $150 to replace the parts, 250 to upgrade to a ruby cantilever (original is aluminum). No lunch money for months. Confused
Re: Dynavector 10X5 Assist [message #68812 is a reply to message #68811] Mon, 01 August 2011 21:11 Go to previous messageGo to next message
Oh, yeah, I've seen 'em get mangled like that too. You're right, if it's twisted, that's bad. I suppose with a magnifying glass and some instruments, you could probably get it eventually but it's probably best to replace it. Might end up breaking it before you could get it back into shape anyway.
Re: Dynavector 10X5 Assist [message #68846 is a reply to message #68812] Thu, 04 August 2011 15:57 Go to previous message
Hi, It is on its way for the upgrade. I'll let you all know if it is better or (hopefully not) worse than before. While it isn't quite a "source" I attached a photo of the latest incarnation of my tube phono preamp. It is right at the -90 dbv spec now and sounds great. I'm still doing tube rolling on it as many are inconsistent on gain or not quiet or even a few just don't sound nice. Best setup at present is input and second gain stages use JJ ECC803S and the output stage is a JJ gold pin ECC81.
index.php?t=getfile&id=566&private=0
Previous Topic: Audio Duration Compression
Next Topic: Sound and Recording iPhone Apps
Current Time: Sun Apr 28 18:39:11 CDT 2024
