Home » Sponsored » Pi Speakers » Terminal Connectors
Terminal Connectors [message #68669] Thu, 21 July 2011 09:42 Go to next message
I am building three 4pi and eight 1pi speakers. Does anyone see any issues with the use of this terminal connector instead of using binding posts?
Re: Terminal Connectors [message #68671 is a reply to message #68669] Thu, 21 July 2011 13:41 Go to previous messageGo to next message
I've used those kind before and they're OK but kind of cheesy. The spring and plastic activator pop out pretty easily.
Re: Terminal Connectors [message #68673 is a reply to message #68669] Thu, 21 July 2011 19:12 Go to previous messageGo to next message
I've posted before that you can't do better than the Pomona Tellurium Copper binding posts, especially now that the Edison-Price are no more.
http://www.alliedelec.com/catalog/pf.aspx?FN=447.pdf
You want the Model 3770s at Allied. No nickel, no brass, and it's audible to me as I've A/B'd with the gold Daytons. I buy the $4 round plastic cup terminals from PE, remove the terminals and replace them with the Pomomnas, an exact fit.
Re: Terminal Connectors [message #68675 is a reply to message #68669] Fri, 22 July 2011 07:18 Go to previous messageGo to next message
I ended up purchasing the Neutrik NL2MP Speakon 2 Pole Panel Mount. Thoughts?
Re: Terminal Connectors [message #68900 is a reply to message #68675] Mon, 08 August 2011 05:29 Go to previous messageGo to next message
Maxjr is currently offline  Maxjr
I love speakons! I plan on using them on my 4 Pi build.
Re: Terminal Connectors [message #68918 is a reply to message #68900] Mon, 08 August 2011 12:27 Go to previous messageGo to next message
I like the pure copper ones, as well, with no plating. I still have an extra set from Percy that I haven't used yet... Copper sounds the best, to me. I also take the stock ones out of the PE cup and "reinstall" the good copper ones. Sometimes takes a little hammering, but then they're in to stay. I use twisted OFC magnet wire inside, all connections soldered.
Re: Terminal Connectors [message #68919 is a reply to message #68918] Mon, 08 August 2011 13:20 Go to previous message
Copper Speakons? I didn't know they exist. Do you have a link? Maybe I'll have to upgrade all of my current ones
Previous Topic: 3 Pi dimensions and QSC 152 waveguide
Next Topic: 4 Pi Speaker Plans
Current Time: Sun May 05 00:40:02 CDT 2024
