Home » Audio » Room Acoustics » Movable Panels
Movable Panels [message #68163] Mon, 13 June 2011 08:10 Go to next message
Does anyone here use movable acoustic panels when recording? Which instrument do you use them for, or are they strictly for vocals? I've seen them used for voiceovers sometimes.
Re: Movable Panels [message #68557 is a reply to message #68163] Thu, 14 July 2011 09:14 Go to previous messageGo to next message
Yes, I generally use them for voiceovers and singing. I haven't actually tried them for other instruments yet, but it would be fun to experiment.
Re: Movable Panels [message #68993 is a reply to message #68163] Sat, 13 August 2011 04:39 Go to previous messageGo to next message
Ebirah01 is currently offline  Ebirah01
I use them a lot when I want semi isolated tracks during a session in which the artist prefers to perform all tracks live simultaneously. Getting full studio separation is simply beyond the capabilities of my little home set up, but using a good set of baffles (home made ones in this case) helps tremendously and offers added clarity and control for each channel.
Re: Movable Panels [message #69003 is a reply to message #68163] Sat, 13 August 2011 14:42 Go to previous messageGo to next message
LizardBat is currently offline  LizardBat
I use plexiglass sheets occasionally when recording louder instruments, such as drums, in a live (in the studio) setting. I have a very small set and a very large free-standing tri-panel set. They work beautifully!
Re: Movable Panels [message #99309 is a reply to message #68163] Wed, 25 March 2026 01:08 Go to previous message
Clint is currently offline  Clint
I've become quite familiar with movable acoustic panels. Since I began using it many years ago, I've noticed an improvement in sound production in the home studio.
I can say that they are very good for neat voiceovers and for singing, but beyond that, I also use them for my upright bass, acoustic guitar and even violin to tighten up the room without messing up the instrument's natural tone.
The one that I've been using for so long now is the GIK Acoustics 244 panels, which I mainly use on tripod stands. It is very easy to set up, move, and also arrange when you are done with the voiceovers or whatever you used it for.
If you've struggled with making headway in your sound production, I suggest you grab a pair, and you will be glad that you did.
Previous Topic: Drapes or Curtains
Next Topic: Same stereo/speakers different sound
Current Time: Sat Oct 24 13:13:23 CDT 2026
