Home » Audio » Thermionic Emissions » Eastern Electric Gear
Eastern Electric Gear [message #8869] Tue, 29 March 2005 05:35 Go to next message
guitarplayer is currently offline  guitarplayer
Anyone who is looking for some reasonably priced gear should really check out the phono stage and integrated from Eastern Electric.
I have no affiliation with Bill and the gang at Morning Star Audio other than I arranged to use the above gear for the GPAF, I am just incredibly impressed that gear this inexpensive sounds as good as it does.
Regards,
Lee
Re: Eastern Electric Gear [message #8870 is a reply to message #8869] Tue, 29 March 2005 06:24 Go to previous messageGo to next message
HI,
It looks good, but seems expensive, given that it's using 6bm8 tubes in push-pull mode. This is similar to the $150 antique sound labs or SE electronics kit that I built a while ago, that uses 11bm8s in push pull.
Th estoetkit that Wayne Parham built cost $550 in kit mode, and used 6bm8 tubes also.
I think the big difference here is the use of tube rectification with a PI filter, and maybe better output trannies. Not having heard it versus the stoetkit, i can;t say. But the price seems a little high. Th esound may be great, I would love to hear it.
Just my thoughts
-akhilesh
I Was referring to the M520 [message #8871 is a reply to message #8869] Tue, 29 March 2005 16:18 Go to previous messageGo to next message
This is the amp I was referring to:
http://www.morningstaraudio.com/shop/custom.asp?recid=6
Regards,
Lee
Re: I Was referring to the M520 [message #8876 is a reply to message #8871] Sat, 02 April 2005 08:13 Go to previous messageGo to next message
Got it. Looks good! I heard the nelson audio el34 with 6sn7: really nicely balanced.
This one looks good too!
-akhilesh
Re: I Was referring to the M520 [message #8878 is a reply to message #8876] Sat, 02 April 2005 17:26 Go to previous messageGo to next message
I'll have it at the show, stop by and take a look!
Regards,
Lee
Re: I Was referring to the M520 [message #8879 is a reply to message #8878] Sun, 03 April 2005 07:12 Go to previous message
HI Lee,
Cool will certainly do that!
This show is such a good idea!
-akhilesh
Previous Topic: Looking for a color code
Next Topic: Continental Capacitor type A oil capacitor info wanted?
Current Time: Tue Oct 20 12:33:35 CDT 2026
