Re: Back EMF? [message #67473 is a reply to message #67469] |
Fri, 06 May 2011 10:06 |
Messages: 18678 Registered: January 2001
Frihed89 wrote on Fri, 06 May 2011 06:21 | What is the difference, if any, between a JBL 2226H and 2226J? Which one is the "right" one?
The 2226H is 8Ω and the JBL 2226J is 16Ω. The one you need is the 2226H.
Frihed89 wrote on Fri, 06 May 2011 06:21 | Is the "wave guide" (please don't eat me alive) for the tweeter on the Four- Pi available from commercial vendors or made to your specs? I am in Denmark.
It's an Eminence H290. I would be happy if you got that in Denmark, as it would save shipping charges. The most cost-effective thing for you to do is to get the crossovers from us and source everything else locally.
Frihed89 wrote on Fri, 06 May 2011 06:21 | What happens (both the good and bad) when you add a super tweeter on the top of the box? Will it help my dog appreciate music better? Or me? I suspect it requires a new or another cross-over, correct?
Do not use a super-tweeter. It cannot be placed within 1/4λ from the tweeter, so comb-filtering will result. You won't need the extension anyway, because the DE250 reaches to 18kHz.
