Home » Sponsored » Pi Speakers » Three Pi & Four Pi Plans
Three Pi & Four Pi Plans [message #66642] Sun, 13 March 2011 17:07 Go to next message
timoteus is currently offline  timoteus
Greetings Wayne,
Would it be possible to get both the Three and Four Pi plans? I'd like to study up on both models before I decide for sure on which to build. Thanks in advance!
Re: Three Pi & Four Pi Plans [message #66643 is a reply to message #66642] Sun, 13 March 2011 20:08 Go to previous messageGo to next message
Please choose one first and I'll send plans when you do.
The boxes are close to the same size, the tonal balance is about the same and the patterns are similar too. The biggest difference is the four π is about 3dB louder at the same voltage drive.
Most people choose one or the other based on the driver families available. The top-of-the-line three π loudspeaker uses the Acoustics Elegance TD12S woofer and the high-end four π speaker uses the JBL 2226. So you're choosing between AE and JBL when you make the decision.
Re: Three Pi & Four Pi Plans [message #66645 is a reply to message #66642] Sun, 13 March 2011 20:31 Go to previous messageGo to next message
I've read from your previous posts that the Fours are 3 dB more efficient and I definitely need that when using my 45 and 2A3 amps. I was just waffling a little bit because I was so intrigued of maybe trying the smaller, faster 12" AE and comparing it to the 15" in my Altec 19s.
With that being said, I think I'll opt for the model Fours.
Thanks Wayne.
Re: Four Pi Plans [message #66646 is a reply to message #66645] Sun, 13 March 2011 20:52 Go to previous messageGo to next message
You've got mail!
Re: Four Pi Plans [message #66647 is a reply to message #66642] Sun, 13 March 2011 21:15 Go to previous messageGo to next message
Thanks for the pdf, Wayne!
Re: Three Pi & Four Pi Plans [message #66994 is a reply to message #66642] Mon, 11 April 2011 02:36 Go to previous messageGo to next message
audiotone is currently offline  audiotone
I am interested in the Four Pi plans.
kind regards,
Tony
Re: Four Pi Plans [message #66997 is a reply to message #66994] Mon, 11 April 2011 08:00 Go to previous messageGo to next message
You've got mail!
Re: Four Pi Plans [message #66999 is a reply to message #66997] Mon, 11 April 2011 08:55 Go to previous message
thank you!
Previous Topic: Rabbet dimensions for flush mounting (4Pi upgraded)
Next Topic: 4 Pi Speakers and 3 Pi Subwoofer Request Plus Question
Current Time: Tue Oct 20 12:22:51 CDT 2026
