Home » Audio » Craftsmen » lubricants for audio
lubricants for audio [message #66233] Sun, 20 February 2011 18:13 Go to next message
When rebuilding old equipment, what do you recommend for lubricants? For switches, sliders, gear tracks, etc.
Re: lubricants for audio [message #66235 is a reply to message #66233] Sun, 20 February 2011 23:21 Go to previous message
There is a cleaner/lubricant made especially for this purpose. It is available at most electronics shops in an aerosol can, usually called "tuner cleaner" or some such thing. Look for it where you buy flux remover. It's not the same stuff, but it's usually on the shelf in the same place.
Previous Topic: High-Pass Filter
Next Topic: Will Longer Wires Reduce Sound Quality?
Current Time: Wed Nov 04 07:50:24 CST 2026
