Home » Sponsored » Pi Speakers » 2Pi Tower Ports
2Pi Tower Ports [message #66079] Fri, 11 February 2011 00:54 Go to next message
Okay so I am a fan of front ports, just prefer the look on tall towers.
Is there any issue with placing the 2Pi tower ports on the front baffle (same x/y locations as rear port spec)? My intent is to use acoustically transparent material on the inside of the baffle (black grille cloth or thin open cell foam) to prevent seeing just speaker guts (in this case the front baffle R11/R13 insulation).
Re: 2Pi Tower Ports [message #66083 is a reply to message #66079] Fri, 11 February 2011 08:12 Go to previous messageGo to next message
I don't think there would be an issue, as long as it was placed in the same place vertically. But I haven't verified that. This speaker is sensitive to port/driver placement, so one should always be mindful of that when deviating from the plans.
Re: 2Pi Tower Ports [message #66084 is a reply to message #66079] Fri, 11 February 2011 10:52 Go to previous message
Got it. I'll stick with the standard rear port location.
Previous Topic: selenium st 324 tweeter
Next Topic: Request...plans
Current Time: Sun May 19 19:17:17 CDT 2024
