Home » Sponsored » Pi Speakers » 2Pi Tower or 3Pi Bassreflex questions
2Pi Tower or 3Pi Bassreflex questions [message #65986] Sat, 05 February 2011 06:52 Go to next message
ecc83 is currently offline  ecc83
Hi,
Which design have a "bigger sound"-the 2pi tower or the 3 π bass reflex and which makes more bass with a 2A3 single ended amp?
Is it possible to build the 2Pi Tower in a wider (and lower) shape?
I am thinking of a 31 x 20 x 15 enclosure...
Thanks
Frank
Re: 2Pi Tower or 3Pi Bassreflex questions [message #65988 is a reply to message #65986] Sat, 05 February 2011 10:00 Go to previous messageGo to next message
These are two very different designs, almost incomparable. But they do have some notable similarities, such as spectral balance. They both work very well with low power tube amps, providing high sensitivity and a benign impedance curve. Beyond those attributes, they are pretty much fundamentally different speakers. They were designed with different goals in mind.
The three π loudspeaker provides uniform directivity, constant above 1kHz and uniformly expanding below that. It is truly a statement speaker, one that provides best of class performance. Especially when it is outfitted with the upgraded drivers, I'm not sure there is a better "waveguide" speaker on the market. Sorry to be a little immodest, but I believe it's that good.
The two π tower is a nice sounding speaker too, but it is designed to be a budget model, a secondary system. Don't get me wrong, it sounds great. Many audiophiles prefer cone/dome loudspeaker systems, and this is one of the best. It's balanced, having smooth midrange, clear highs and deep, full bass. But designs like this cannot maintain uniform polars like the larger horn models do. They're just not in the same class as the three π speaker.
Re: 2Pi Tower or 3Pi Bassreflex questions [message #65990 is a reply to message #65988] Sat, 05 February 2011 10:33 Go to previous message
Wayne,
thank you very much for your detailed answer!
Frank
Previous Topic: Here I'm again
Next Topic: Jumping the gun, but a few questions
Current Time: Fri Nov 13 02:57:50 CST 2026
