Home » Audio » Pro Sound » Speaker for Home Office
Speaker for Home Office [message #65821] Mon, 24 January 2011 07:58 Go to next message
jazzlover is currently offline  jazzlover
I find the 3.1 speaker I bought an overkill for the computer that I use in working at home (I have a home office). Switching to a headphone annoyed me after a while (long list of discomforts). Got to find a speaker that's just of the right size and intensity.
Has this happened to you? Smile
Re: Speaker for Home Office [message #65826 is a reply to message #65821] Mon, 24 January 2011 14:23 Go to previous message
I would personally go with 2-way bookshelf or small monitors that can get down to at least 60hz. I'm not a fan of subwoofers as a bass frequency replacement (20-280hz), but maybe you are, so take that into consideration. I would likely choose something that has a lot of mids for low volume so that when they compress at higher volumes the bass and treble will get louder and not the rest so much. That way you can listen to them at a lower overall volume.
Previous Topic: Headphones for Tinnitus?
Next Topic: Rental instruments or Purchase?
Current Time: Thu Nov 26 18:19:47 CST 2026
