Home » Audio » Thermionic Emissions » replace cat eye tube for cad 808
replace cat eye tube for cad 808 [message #8427] Wed, 01 September 2004 08:43 Go to next message
adavis464 is currently offline  adavis464
are they easy to replace regards Tim
Re: replace cat eye tube for cad 808 [message #8428 is a reply to message #8427] Thu, 02 September 2004 08:01 Go to previous messageGo to next message
The Cary Rocket 88 sure is a beautiful amplifier!
Cary Audio CAD-808
About the eye tubes, are you asking if replacements are easy to find? Or are you asking if they're physically easy to replace? Surely it isn't just an adjustment, but have you checked the intensity adjustment, just in case?
Re: replace cat eye tube for cad 808 [message #8429 is a reply to message #8428] Thu, 02 September 2004 08:35 Go to previous messageGo to next message
no its out completely
Re: replace cat eye tube for cad 808 [message #8430 is a reply to message #8429] Thu, 02 September 2004 08:51 Go to previous messageGo to next message
Bummer. So are you wondering about physical replacement? Have you opened it up to see how it is mounted? Or are you worried about finding the tube? Now that I think about it, I'm all questions and really no help am I?
I know some eye tubes are sort of scarce, but I would expect you'd be able to find replacements. If nothing else, I would expect Cary would sell you a tube. I'll bet the guys at VTV would too, and now that I think about it, there are probably plenty of other sources.
Have you seen Eric Barbour's article on eye tubes? If you haven't already seen it, check it out - It's interesting and has some great information.
e-mailed cary and [message #8431 is a reply to message #8430] Thu, 02 September 2004 15:27 Go to previous messageGo to next message
Dennis Had explained in detail how to repair it my self.thanks though for the help. regards Tim
Cary Audio [message #8432 is a reply to message #8431] Thu, 02 September 2004 17:59 Go to previous message
Sounds like they're really nice people with good support.
Previous Topic: 47 tube
Next Topic: Transcendent SE OTL and Pi speakers
Current Time: Sat Oct 17 19:14:28 CDT 2026
