Home » Audio » Silicon Valley » AMP cracking and popping
AMP cracking and popping [message #64884] Wed, 24 November 2010 19:47 Go to next message
compguy is currently offline  compguy
When ever I plug my guitar into the input on my amp and start playing, even if the amp is not up very high, I get a pop every so often. It doesn't seem to happen all the time, and usually not when I'm playing anything in particular. I checked my input, and it does seem slighly loose. Does this sound like a serious problem?
Re: AMP cracking and popping [message #65009 is a reply to message #64884] Tue, 30 November 2010 13:11 Go to previous messageGo to next message
Corded is currently offline  Corded
Quite possibly an arcing problem, which may have something to do with the loose input, or may not. If it's only recently started happening and the input used to be tight, I'd try correcting that first.
Re: AMP cracking and popping [message #65021 is a reply to message #64884] Tue, 30 November 2010 15:23 Go to previous messageGo to next message
compguy wrote on Wed, 24 November 2010 19:47
Pops generally signify something before it even touches the amp. Try another amp or the computers input and get back to us on whether or not it disappears.
It wouldn't happen to be a muffled scrapping sound would it?
Re: AMP cracking and popping [message #86206 is a reply to message #65021] Thu, 28 September 2017 10:35 Go to previous message
Ziggy is currently offline  Ziggy
Check all the pickups on the guitar for loose fittings. Like the guy above said, it usually means that there is something wrong before it ever gets to the amp. I'd hate to see you short it out and wreck your equipment.
Previous Topic: Comparing two amps
Next Topic: Amps for Home
Current Time: Thu Nov 26 12:30:32 CST 2026
