Home » Audio » General » Inserting Output Plug Into Input Socket
Inserting Output Plug Into Input Socket [message #64803] Sun, 21 November 2010 22:32 Go to next message
Jorel is currently offline  Jorel
I have mistakenly inserted my headphone into the microphone socket in my computer. Honestly, I have done it a lot of times. Will this create a problem in my sound card? Right now, I need to insert the headphone plug just halfway because I won't hear any voice when I completely insert the plug.
Re: Inserting Output Plug Into Input Socket [message #64805 is a reply to message #64803] Mon, 22 November 2010 00:38 Go to previous messageGo to next message
Damage? No.
Plugging headphones into the mic input of a computer inverts the poles and tuns them into a transducer though, which is interesting.
Re: Inserting Output Plug Into Input Socket [message #64869 is a reply to message #64805] Wed, 24 November 2010 08:04 Go to previous messageGo to next message
Now that I know it didn't damage the hardware, I need to find out what caused the problem of speaker output of the sound card.
Can you explain a bit how plugging a headphone to a microphone input will result to a transducer? I thought microphones and headphones/speakers are already transducers.
Re: Inserting Output Plug Into Input Socket [message #64874 is a reply to message #64803] Wed, 24 November 2010 11:35 Go to previous message
The headphones only working halfway in usually means that the wiring has a short in it. A stereo headphone plug is a tip-ring-sleeve configuration and if you get sound with only two of the three contacting the jack and nothing with all three, then there is a short.
You say the hardware is fine on the card/mobo, but I've worn out many headphones jacks. I didn't know how at the time, but eventually you can wear the metal down to the point solid contact becomes impossible
I usually only call a microphone or guitar pickups a transducer myself, so that might have been confusing. Inverting the polarity of any speaker turns it into a (piss poor) microphone and vice versa. Microphones don't make good speakers as you can imagine except for certain supertweeters over the years doing this.
Previous Topic: Help Ma Wee Grannie !
Next Topic: Origins of Power
Current Time: Thu Nov 05 02:53:28 CST 2026
